Hello All,
Thanks in advance for your help.
My 2003 LC (355,000 miles) is suddenly having an issue and we can't figure it out.
The number one issue is a serious loss of power, especially when going uphill. At the same time the fan becomes very loud.
I'm not very knowledgeable about engines, etc., so forgive me if I use the wrong terminology... but I will do my best to give you what info I have.
At first I it felt like the beginning of something that had happened years ago, where the c clip near the axle popped out causing the splines to separate and eventually strip out completely.
My mechanic checked and said the c clips are in, so he didn't think that was the issue.
He thought the loss of power was an exhaust issue, especially because she's been throwing the 0420 code for awhile. But the muffler shop said he tested the cats and there was no backpressure, so they were clear.
I then took it to the transmission shop. Out of nowhere, he pulled a code that suggested it was a coil and nothing indicating any transmission issues. So my mechanic flipped a set of coils and plugs and since the code moved he replaced that coil.
Now we are back to where we started....A loud Fan and no balls.
I've had her for 20+ years and put 330k of her miles on her driving my kid all of the place, nearly all on the highway. These last few years though, I've only driven her about 5k a year.
From 2022 to the beginning of 2024 I've done the following:
Aisin Timing belt kit
Aisin Water pump
Crank Seals
Eyelet Pulley
Cam Seals
A/C Compressor
Condenser
OEM Valve cover gasket
OEM Starter
OEM Serpentine Belt
OEM Fan clutch bracket
Misc Water hoses
KYB Front and rear shocks
Denso Alternator
Fuel Filler Neck
Fuel pump
Radiator
If any of you have any suggestions or questions, please let me know.
Thanks
BTW, I'm in Southern California.
Aisin Water pump
Crank Seals
Eyelet Pulley
Cam Seals
A/C Compressor
Condenser
OEM Starter
OEM Serpentine Belt
Misc Water hoses
Denso Alternator
Fuel Filler Neck
Fuel pump
Radiator
Thanks
