I'm installing a clutch for the first time and have a few questions I was hoping someone could help me with:
1) Rear Main Engine Seal: When you do the clutch does it make sense to also replace the rear main engine seal? If so, how do you get the fawker out of there (and the new one in)?
2) Hub Clutch and Throw Out Bearing: I don't have the old ones to look at but these arrived as two pieces. I assume I need to somehow pound the Throw Out bearing (with the flat side facing down) so that it fits onto the clutch hub (which I would lubricate with a little bearing grease)? Any advice on a good technique to do this?
3) Lubrication: The only thing I need to lubricate is the actual tranny output shaft splines -- correct (all the bearings are sealed)?
4) Adjustment of the clutch finger screws: All the stuff I'm getting is new out of the box -- is it likely I will have to adjust the screws on the end of the three clutch "fingers"?
TIA.
TIA.
