Crank seal leak...maybe?
I have 96 FZJ80 that appears to have a crank seal leak. I sprayed the underneath of the engine/surrounding area where the oil was w/degreaser yesterday, hosed down and today took it in for inspection at local foreign auto shop. Put a camera scope to the underside of the crank seal area where he showed me what looked like seal leak. Getting under it just now, looks like it could be that or could it also be something else? I have attached what pics I could angle-very difficult to view the crankseal w/ cam lense but there is leakage there-Keep in mind what oil you can see is from today as I degreased underneath yesterday. It doesn't appear as bad as others I have seen posted here but my concern is timeline, urgency of repair based on what I was told to expect for cost of the job, parts being minor and labor being major. Since I don't have the tools nor the skill to do this, looking for some wisdom and someone to tell me something encouraging. Gut tells me likely is crank seal but what if its timing pan leak or something else that's weeping into the crank seal. Engine has 168k and probably hasn't undergone a new one.The drippage from part below the oil filter(which is tight and no drippage there and no recent oil change so ruled that out). Don't know what that is, oil pump-not sure -$1500-$2000-ouch
