I’m in a serious pickle. I have a 1971 FJ40 front axle that I did a disc brake conversion on in 1999. I’m rebuilding the front axle now. I bought a new bronze bushing and (although it slipped over the axle shaft prior to inserting the axle and before I pressed fit the new bushing in the axle tube). I did not realize how tight this damm thing would end up. I’m chugging along just trying to do my best at fixing and replacing everything. So don’t beat me up.
The old bronze bushing got tore up from a broken upper knuckle bearing that broke apart and chunked up inside the bell housing. I managed to pull out the old. Put the new bushing in. But had no idea I was supposed to hone out this bushing. I went to insert the axle shaft back in after I rebuilt the knuckle with new bearings. And it was a pita to go back in cause 1. My disc brake conversion I had to grind shave off some of the birfield flat spot to get it to go in wayyyy back then. It all worked before. So it was a little tight going back in. Once it finally slipped into the Detroit ez locker , I was like oh crap. Now the axle won’t spin freely at all. It’s tight as can be. I pulled the drivers side axle out and I can visually see the pass axle inserted into the diff. I even mounted the spindle and rotor just so I could mount the tire and I can get the tire to spin, it’s difficult but it spins the diff with the locking hub engaged.
So NOW IM TRYING to get the axle back out. I am at my Witt’s end. Need help removing this pass side axle. It is stuck. I can’t pull it out. Any help is greatly appreciate.
