I bought this '94 in seven or eight years ago and it came with this hitch installed. I've never towed anything, so looking for help to ID the class of hitch so I can determine whether a 400lb tongue weight (motorcycle carrier + XR650L) is within spec. Thanks all!
400 lb sounds like a lot of tongue weight. Are you sure the load was properly balanced, etc when that was measured?
The hitch looks similar to the port or dealer installed receiver hitch commonly used on the 80 series, but different enough I think was added be someone else. Pretty sure the Toyota-supplied hitch was a bolt-on, where this one is clearly welded on.
To me that looks a lot like a homemade hitch given the cut angles on the upper support and the welds pictured. A lot of the industry built hitches would have formed bends in either the gussets, mounting plates or main body of the receiver.
:edit:
Found a very similar hitch in craigslist. A Reese class 3 for a Tacoma. Looks identical
Worked out just fine. Picked the bike up in Prescott, AZ and drove it to Big Bear, CA no problem. Didn't even bounce around much with the AMC-400 hitch carrier.
I will say I had a little squat which didn't effect the drive quality much, but DID effect the braking! Holy s*** batman, without the back end coming up, the LPSV or whatever doesn't do its thing = braking power dramatically reduced = not cool. Definitely need to get those air bags in there.
