Hey guys I need help making a screw compressor.
I bought a wrecked atlus copco trailer mounted screw compressor.
Motor is toasted and a fortune down here.
I found it in the local scrap yard with a blown motor and no head.
I pulled the screw head and cleaned it all up.
There was some of rust but cleaned it all out and oiled in for storage in my shop.
Some pitting but mostly surface rust from sitting here with the high humidity.
It seems in good shape and should do the trick. Not perfect as I said some pitting.
I really don't Know Jack s*** about this type of compressor head.
I have lots of 2 stage units and want to eliminate these.
I need the High CFM for sand blasting.
At the moment I have a duel head 2 stage with double 5 hp motors.
Makes about 50 cfm.This is the biggest thing I could make with the 1 Phase electric at the shop.
I need more air for sand blasting blasting.
I have thought about looking for another motor but the 3 cyl diesel is a small fortune here and NFG.
Wondering if any of you work in this racket and could help me out with tips and advice.
As is the motor that was in it was pushing out 35 hp.
Wondering if I could hook up a 4 cyl gas motor with the same HP and use this.
I would set up LPG to keep the fuel cost down.
This trailer model here is well over 5K used and I got it for the price of scrap with the hope I could make this head work.
I can't afford the 5 grand or would just buy one and not mess with a wreck.
Thus far I am into it for about $700 in tools I traded with the owner.
The model is a copco XAD 96 if that helps any of you in this biz.
I could post fotos but not really any point as it is Fugly.
So what I am asking is can I use a 4 cyl. gasoline motor in place of the 3 cyl diesel?
Could I hook an electric motor single phase up to the head and change out the 2 stage heads I have?
Do these need the HP and high rpm or to make the CFM?
I used my Milwakee hole hog to spin the screw head.
Thinking maybe I could hook up a 5hp motor and spin it?
No idea what kindda CFM it would put out or if it would even work.
Any help & tip always appreciated.
Steve is Hammered on
in CR.
in CR.
