Help installing new DC drive shaft
Beaumont, Texas
Website
www.marklowimagery.com
Just one real quick question about installing and torque settings. I know that the FSM says to set the bolts to 54 ft-lbf but I am having trouble getting a 14mm socket and uv adaptor on the bolt heads because the new DC shafts joints are larger than the OEM. I have the wheels off of the ground so I can rotate the shaft for best shot but the torque wrench head still binds up on the DC joints. What is the best way to get to these fastners to be able to apply the proper torque setting? Perhaps there is a better tool for the job or something.
Mark
I used a 14mm six point wrench. 74 ft. pds. is the "OEM spec."
I say tighten as much as you can physically tighten and you should be good to go. Another option would be to use Locktite, but then you will have trouble removing the shaft if you need to.
I was able to tighten the 4 nuts at the xfer case side by turning the shaft until I had good angles to attack the nut from the PS of the truck with the front end of the shaft not attached to the 3rd member, but hanging over the relay rod behind the axle. That way you can move one end to get access.
This isn't really difficult once you figure it out.
-o-
Well my FSM says the four bolts on the front shaft are 54 ft-lb and the rear is 65 ft-lb... Oh I see... you are talking in N-m so 74 N-m front and 88 N-m rear. Well I did find a 1/4" 14mm 6 point dedicated swivel socket and with a 3" extension with 3/8" adaptor, I can get it alright but I don't trust that it can handle 54 ft-lb without breaking. I was able to get to all of them with the OEM shaft but this one is a little different story. I know it can be done and should be simple but having just the right tools would make it nuch easier. I am afraid to just pull them down with a wrench as much as I can without knowing the tourque since these drive flanges are subjected to a great amount of force which would either cause them to break of simply back off. I guess I could pull them down tight and apply a anti-tamper red paint line so I could visually see if they have backed out. Oh well, one thing I need to do is put the wheels back on the ground to hold the shaft in place while I tighten and just roll the vehicle back to rotate the shaft for best angle. I'll figure something out, I just wanted to hear some other ideas.
Sorry, yes, you are right on the torque specs. for foot pounds. I was looking at the wrong column. :doh:
Use a 3/8 socket that is universal.....don't use a 14mm socket on a universal adaptor. You need to invest in a set of metric universal sockets that are already jointed--Sears has these for a reasonable price...$30-40, IIRC. The end is a socket and the attachment is already jointed which makes things real easy when dealing with drive shafts.
Use an extension (I have a nice pipe that I cut that fits on both 3/8 ratchet as well as a 1/2 ratchet. Gives great added torque) on the ratchet end and you will get double the force that you are putting on it. And yes, having the vehicle on the ground and having the tires act as a backing force is a good thing.
Put the xfer in 4L and then tighten each nut. With the xfer locked the drive shafts won't move. These nuts by the way are special from the factory (if you are using OEM). They are locking nuts IIRC, though Dan would have to chime in on that.
Yeah, having the right tools is indeed a good thing. Well, these types of experiences make you go out and buy the right tools. At least, it does for me. That way you'll always have the right tool.
-o-
Yes, I agree that investing in the necessary tools for a particular job is a very good practice and I am always finding myself doing just that. I do need to get a full metric set of the swivle sockets in 3/8". For some reason a few months ago I picked up just a few of thest in 1/4" drive (10mm, 12mm and 14mm) thinking those would be the most often used but tomorrow I will go to Sears and go ahead and get a new complete 3/8" set. Many times when I just go to sears to look, I find myself getting overwhelmed and end up leaving without anything at all. I have to have a specific tool in mind when I go and that way I come back with more tools but sometimes not the one I actually went to get. Oh well, I am going to go back outside and finish up what I can and pull everything down tight and I can recheck it after I get those uv sockets. Thanks Beno, I just don't want to try to use the wrong tool and have it slip and round off the hex nuts and bolts, then I will really be up the creek.
Mark
I forget the order. Front or rear first but if you torque the ones that are the most difficult to reach prior to starting on the opposite end, it's not too bad. I'm saying to leave one end of the shaft dangling. I usually use a 3/8 six point socket with the wobbly type extension (instead of a swivel) and a torque wrench. Good luck.
