Freedom,
I agree with Gumby (Did I say that?). If you have some cash and want to lift it anyways, try a new set up springs shackles, pins (all greasable) and shocks. Thats about $800. If you aren't ready for that. Buy new bushings, shackles and gressable pins. Rocky mountain cruisers has these for sale. Bushings are the plastic like material that goes in the end of the springs, the pin then goes through the shackles and bushings. This fix will help if you are not getting the movement between your spring to shackle to frame. You would need all of this even if you bought new springs.
You can then try shocks. Get some that will extend later if you want the lift. Then all you will need will be springs if you want the lift and you won't have wasted any money.
This is not a Cadillac. Its a spring based suspension system and will ride like a truck. If any of the above are bad, they will make it ride harder.
