Help identifying
CSteppe82
Woodlawn
Can anyone tell me what this is ?
Thanks
6/71
Reverse light switch would be on the trans.
The mount for the reverse switch is on the firewall rib just above the steering column and next to the voltage regulator.
The 71 I had first was a three speed and the switch was on the firewall. Yours may still be there. The wiring will have to be rewired to the floor shifter if it has the backup light switch capability.
The problem I am having is that the reverse light stays on constantly. If I turn the truck off it will go out.
Evidently the switch is either stuck in the on position or there is a short across the switch making it stay on. If it goes out when the ignition is off that is because power it is on a switched circuit.
On the three speed with floor shift the switch is on the top plate on the transmission. It is threaded on the back side it the tower the cane fits in. When the shift cane is in the upper left for reverse the cane below the pivot point pushes the plunger on the reverse light switch in on the back right. On the column switch the reverse light switch is clamped to the steering column is such a matter that when the shifter is moved to reverse the switch plunger is pushed in. It can't work with a column shift. I currently have a three seed floor shift cover clamped to a bumper looking angle of different five speed shift canes. Could post a picture of as well as the reverse light switch in my 70 with the column shift.
OP lists a 71. If original column shift the reverse light switch is at the base of steering column just above the steering box.
I love the depth of knowledge here.
CSteppe82,
Did the reverse switch ever work correctly since you have owned the truck? If it did it is a bad or stuck switch on the three speed tranny. However, if it never worked and has always been on then the issue is this: If the original reverse switch is still wired under the hood but you have no linkage attached to push the switch in when not in reverse, then the reverse light will always be on. This is easily fixed. Temproarily you can tape it shut to turn off the reverse light.
The fix:
Check to see if your three speed has the reverse switch mounted and that it works. If it doesn't have one, get one and install it.
If it does have one that works, I can build you an extension harness that will plug into the wires under the hood and extend them back to the three speed tranny reverse switch wires.
