- Thread starter
- #21
Finally home. Check it out. It has a B but next to it not sure as if something fell off. There looks to be a change in color. Or maybe i'm just imagining.
It's a B. The space next to it has been machined flat and is where the original casting would have two different casting marks. I believe these older B blocks were common with the 2B block, but I am not sure. The post 1988 B blocks (which yours is definitely not) were common castings with the 11B. This casting is shown in a post quoted earlier in this thread.Finally home. Check it out. It has a B but next to it not sure as if something fell off. There looks to be a change in color. Or maybe i'm just imagining.
You were right from the get go then.I believe that is a B. 3.0 litre 8 valve diesel. There should be a casting on the intake side of the engine, at the top of the block, under the #4 cylinder intake port. It's no younger than July 1988 and (less sure about this one) would say it is no older than 1984 or 1985.
Not a stupid question. Have a search for BJ40 power steering kits.This might be a pretty stupid question. But being a B engine, would i be able to add power steering to it? Would it be worth turboing it?
I would love for this car to be my daily driver, I don't want to travel at 85 or anything but, I definitely want to be able to hop on the freeway and not cause a traffic jam.
Good point. My understanding is that only the 1988 onwards B engine (aka Bii) had nozzles. The OPs engine clearly pre-dates this.Power steering works fine. Turbo is not a good idea. The pistons do not have oilers like the 3B from what I understand. This is the biggest downside to the B
People have mixed results when turbocharging the 3B, it needs to be a conservative tune as I understand. As Mitch said however, the B is even less suited than the 3B as it does not have piston cooling oil nozzles.
Out of interest, does your engine have a rotary or linear inkection pump?
My understanding is that all 3Bs have them. But I'm talking about the B specifically in the post you quote, not B Series engines in general.My 1985 3B had oil nozzles.
I'm talking about the B.
They were in Dynas until the mid 1990s. But as a much improved Bii with monoblock, roller lifters, oil squirters etc. Same block as the 1988-on 11B.What was a B engine doing in anything after 1988? They were phased out AFAIK much, much earlier.
Then, they weren't called B engines. I haven't found one listing showing a "B" engine in a Dyna that late.
Me too actually. I didn't realise that the B engine had no oil nozzles until so late. I thought all B Series engine had them from the early 1980s when the 3B was launched.That’s fúcking sick! Learn something new everyday.
Rad.![]()
It's late but i grab this pics. Let me know if this informs you of what type it is. If not, I can take some again in the morning.Out of interest, does your engine have a rotary or linear inkection pump?
Man, i don't know well enough to be happy or bummed out just yet. Not really sure if I should swap it or keep it. I'll take any advice!Thanks for checking! That is indeed a rotary pump. This means the engine came from a JDM Dyna/ToyoAce truck. The pump has an idle-up actuator, meaning that the engine once had an AC compressor.
What is your primary concern... just more power? I'm swapping my B for a 13-BT for something with a bit more power, a bit more modern, and hopefully a bit less stinky! I have to stick with a diesel because of Cali. The 13-BT was a relatively painless swap for me because it is basically the direct replacement. One thing for you to consider is the transmission shaft, and I believe the bell housing too, is unique to the diesel engines, so swapping to a gas engine would require the trans too or at least a new input shaft with rebuild. I say enjoy it until it breaks and then decide.Man, i don't know well enough to be happy or bummed out just yet. Not really sure if I should swap it or keep it. I'll take any advice!
Man, the sink is no joke!What is your primary concern... just more power? I'm swapping my B for a 13-BT for something with a bit more power, a bit more modern, and hopefully a bit less stinky! I have to stick with a diesel because of Cali. The 13-BT was a relatively painless swap for me because it is basically the direct replacement. One thing for you to consider is the transmission shaft, and I believe the bell housing too, is unique to the diesel engines, so swapping to a gas engine would require the trans too or at least a new input shaft with rebuild. I say enjoy it until it breaks and then decide.
