Not entirely sure it's a permanent solution here, but apparently some silicone spray on the lower pulley shut that sound right up.![]()
I haven't fixed it since money was tight (because I had just installed a lift) and the sound went away on its own as the weather warmed. I am going to replace the tensioner though and the belts.I am very interested in the solution to this one as I have exactly the same noise on cold start for about 5 minutes.
AugustLab...did you find what the problem was??
Cheers for that....might have a look at my tensioner as well.I haven't fixed it since money was tight (because I had just installed a lift) and the sound went away on its own as the weather warmed. I am going to replace the tensioner though and the belts.
OK so I finally got around to this issue and it was the AC Tensioner Pulley. I went ahead and put new belts on all around as well. All good now. Thanks for all the feedback on this post.I am very interested in the solution to this one as I have exactly the same noise on cold start for about 5 minutes.
