Help identifying control arm extra parts
Rogersville, Mo.
I just finished removing rear axle and found 2 washers on the ground. Removed axle with control arms attached.
I feel like it's some sort of shim. Much thinner than washer on bolt.
95 cruiser had 2. 97 I'm switching to had 1. Didn't see any til I had axle housing out of truck
One of the links or panhard because it has the locks on the head don't know bout extra washer
i know what the bolt, washer and nut are for. Just used them for comparison. The one thin washer is what i am having issues figuring out.
I am wondering if there is or can be a reason to shim the upper control arms
nope. shocks had been off a while. Found these basically directly under where the upper control arms mount. one under each arm. I found one under the other truck in the same general area. I think they came off the arms inside the mounting bracket but can't say for sure or why.
I removed the rear axle in both trucks with upper and lower control arms still attached. These are 24mm bolts and everything else i removed were 12mm ( maybe 14mm) The only place that these washers could have been bolted on were on the shown control arm bolts or pan hard. Just don't know which or why
I have FSM and this pic. Dont see any reference to an extra water or two.
