Help identifying aftermarket radiator
Western Nebraska
Just picked up a '92 FJ80 yesterday.
I did a thorough once over to start learning the ins and outs and planning all the necessary repairs/maintenance/etc.
It has an aftermarket aluminum radiator but I couldn't see any markings to show manufacturer. While checking things out, I squeezed the upper hose (while the vehicle was off and cool) and water passed right through the radiator neck and out to the overflow tank. So, I'm assuming a new cap is necessary.
I'm sure I could go down to the parts store and take the old one in to find a new one, but to make it easier to find a proper cap, I'm trying to find out which radiator I have. Also, I have the typical Land Cruiser OCD and want to document and research everything aftermarket on the truck...
I also discovered that it appears to be straight water for the coolant rather than an antifreeze mix. The truck came from the Pacific Northwest, but that won't fly in Nebraska...and it's obviously not good for inhibiting corrosion...
Don't mind the nasty wiring...just more handy work that I'll have to fix... Part of the wiring mess is an electric pusher fan that's turned on with the headlights... WTF? :bang:
Thanks for the help!
Shepherd auto parts?
Too bad, you missed out on the lifetime warranty.
Pusher fan, straight water and an aftermarket radiator. Does that spell PO overheating issue? It would to me. You may want to do a good cooling system flush.
I would pay close attention to the fan clutch. If not ROARING at cold startup, it may need to be changed out or just juiced up with some 15K CST silicone oil.
Not a bad guesstimate. I haven't seen any signs of overheating but I'll keep a close watch on it. The pusher fan only runs when the headlights are on...why it is wired that way I have no idea. Who knows...?
The PO said he did the rad, water pump, and tstat as PM. Also, I believe that aftermarket rads are the only thing available for the 91-92s so the aluminum makes sense.
I flushed the system out and all looked good. Clean water, no sediment or weird stuff. I feel pretty fortunate that I checked and didn't just assume the coolant was good, though. I put in just a bit over 2 gallons of straight antifreeze. I need to pick up a tester and will check to see if I need to add more. We see temps occasionally dip to -20 deg F, so I don't want to mess around... It got down to 10 deg F last night!
Good call. I'll put it on the list of stuff to check out.
