help identify ticking.
Just curious on the differences between our noises.. I may pull the pump back off and recheck it or something.. Thanks for the advice!
you can certainly run the motor without the pump. That will tell you right there if you are looking at the right thing.
So it won't blow out everywhere if I run it without the Pump in?
I was sick to my stomach after i spent months rebuilding my motor and when i went to start it the first time the same tick was there! I was like Holy WTF is that!!!! But, i did get a killer motor rebuild out of it all and a lot of experience and knowledge... so....
Haha yeah. Mine is ticking sounds like coming from middle of head. I thought it was a valve but the clearances were all good. It runs great but sounds terrible. The noise has stopped a few times but only for a few seconds. I hope the pump is all it is...
Hello,
New to the board and having the dreaded power steering pump issue. Recently purchased a well maintained norther Cali 97 Cruiser. Had my local mechanic look it over and the power steering pump had a slight leak so we replaced it while doing the normal tune up plugs etc. it ran wonderfully before and came back with the ticking sound. Thanks to this board I was able to help him understand the likely problem. So they want to do a new oem pump and a new gear. This sounds fine with me but if they don’t seat that gear correctly I will likely have the same noise? So I was hoping concrete jungle might read this and maybe have some ideas. I believe you know a lot more than the mechanic I have working on it unfortunately. Hard to find a good one in Minneapolis that knows these FZJ80’s well.
Thanks, John
Hey Concretejungle,
Very new to the board and to the 97 Cruiser I purchased. Have questions on the power steering pump conundrum and curious if I could ask you some questions? My mechanic needs help!
In my case holding the pump with wood in a vise and torquing the nut that holds the gear into the shaft worked. Torqued the nut with torque wrench to seat the gear and no problems. Just as its printed in the Factory Service Manual.
Just replied to your PM... Do what Ted said, use a vice and protect the gear with wood or something material, then torque the nut down.
Thanks for the response. Much appreciated. Wish me luck. I think I am going to need it as I hope they would have torqued it down to the 54 lbs service Manuel already. I was hoping there was maybe another silver bullet to correctly seating that gear. They have literally had my truck for a month. Screwing around with different pumps from different manufacturers I think so their labor is covered when they return the pump.
I don’t think the torque spec is what counts in this case. Unfortunately you have to torque the gear down to have it line up with the internal gear just right otherwise there will be gear chatter aka ticking
Yes. And my guy has looked at it now on the old pump and then on the new pump and it sits differently. Buying a oem pump and we will see what happens. The gear looks perfect so not buying a new gear. Fingers crossed.
I was lucky enough to be going from OEM to OEM pump with a new gear to boot. Measured the gear on the old pump and new one was the same.
Good Luck!
Ok so my nightmare tick still isn’t over. The next try will be with a new gear as the old one on the new oem pump torqued to 54 still provided a tick. They also ran it with no gear and it purrs like the kitten she is. So there is no doubt it is the gear. My question for you both is your opinion on the 54 lb torque spec. Our next attempt will be new oem pump, new gear. My mechanic does not want to torque it down any further than 54. Does he potentially need to? Second question is if a new pump and new gear torqued at 54 lb still produces a tick is there a chance that after driving it a while the gears will better mesh together getting rid of the tick? I can’t hear the ticking inside the truck but outside it sounds like well....it doesn’t sound like it is purring.
His other suggestion is getting all new gears in there (oil whatever else’s)and that is a ridiculous project for a tick.
I always loved these trucks. Their looks. The Front and rear lockers. They are legendary for running forever and being the most over engineered suv ever. At 6’3 I mistakenly assumed the Japanese knew there were folks taller than 5’10 over here. And this power steering pump design is really curious vs a belt or something. Just venting as I plan on taking care of the seat room issue and hoping to get this gear ticking resolved. Thanks again for your opinions...they are much appreciated. Sorry for venting. Just super frustrating
I would torque it past the 54 lbs of torque. To me, it wasn't the torque measurement, it was the clearance.
Thank you sir. I am not sure I understand why he is so skeptical on torquing it more than spec and I will mention the clearance part as I think he has some dye to try and see how it fits before it is all put back together. He had to pay some service called something like Idelix? Who likely has retired Toyota techs on staff to answer questions like this and they said to just drive it and the gears will mesh together. I am not sure I have another option if the new gear doesn’t make a difference.​
Should have closed this out long ago in case someone else runs into the same issue. New oem pump, new gear and she idles and purrs. Not certain why the new gear made such all the difference....maybe they knicked it but one couldn’t see anything with the eye. Thanks again for the help.
glad to hear you got this fixed. It's crazy how loud the PS pump gear can be if it's not aligned perfectly. Many, including myself think that you are having engine failure when it's just a chattery gear.
