help identify ticking.
North Cadillac
Short story is my truck sat around for about 4 months while i was broke and waiting to order a HP power steering hose and a few other parts. While it was down, my distributor O-ring was leaking horribly so i took the opportunity to replace it. I didn't think the process through completely and when i replaced the distributor it was 180 degrees off.
Figured that out pretty quick and installed correctly.
Ever since i installed the distributor the motor has a metallic click. My neighbor said it sounded like a sticking lifter and it should eventually go away after time. Well after about 3 days of driving it was still just the same.
So i changed the oil with no change. Then i put in some marvel mystery oil. Drove it around for a few more days, no change. Took it to a mechanic and asked his opinion, he said it sounded like a sticking lifter. He said he would just drive it.
Well, it has been about 2-3 weeks and it is still just as loud as it was the first day. No change.
My question is with my limited experience, is there a way for me to take off the valve cover and see if there is a sticking lifter? Do i have to remove the head to discover if it's a lifter or a bent valve?
Any advise is appreciated.
We have gotten some significant snow here and it sure is fun driving the 80 again and leaving the boring LS at home for a little while. :steer::hillbilly:
I have had this on two cars of mine that spent time sitting. I added a quart of Rislone to the oil and it literally stopped the ticking within just 30 seconds on both cars. Just add the rislone in lieu of a quart of oil. I have had great success with this and it isn't expensive.
*Both cars I assumed it was sticking lifters and i was right, cured with Rislone.
Good luck,
Chris
Well,
my itch is this..... i have about 213,000 miles on my motor. The truck is pretty much a wheeling and exploring truck now and i am trying to prepare it for long trips. I am at the point where i am thinking of a HG in the near future which means i need to take the head off, which means i would like to port/polish the head, while i'm there it makes sense to me to do new rings, valve regrind.... which means Landtank is selling a kick A$$ turbo manifold..... you see where i'm going with this.
So, for the time being while there is snow around and i don't have a garage or extra $$ to do the job the way i want to do the job, and that my rear wheel drive LS 400 does NOT like the snow, i just want to stop the ticking and make sure that the motor is not going to die on me or throw a rod.
I could do a valve job but doesn't that mean if something is out i need to replace shims? And to get to the shims dont you have to take the head off? I need to look at the FSM more.
Negative. Valve adjustment is done with the head on the truck.
1. Take valve body off (you don't even have to take the cables off, but this is a good time to check wear on cables--at least the accelerator cable). You will need a new throttle body gasket: 22271-66010. I have a spare I can send you.
2. Take valve cover off. Cams and valve buckets will appear. You will need a new valve cover gasket for when this goes back on. 11213-66010 I have a spare I can send to you. Also a good time to do your spark plug seal gaskets--you will need 6 of them, I have spares.
3. Get the FSM and it has the correct readings for the valves. Exhaust specs: 0.25-0.35 Intake specs: 0.15-0.25 (looking at the engine head on, intake are the right hand valves buckets, exhaust are the left hand valve buckets. The FSM has a formula for figuring out what shims you will need once you measure each of them.
4. FSM also has the correct order of reading valves for adjustment: 1, 3,5 (two on each valve) on the exhaust, 1, 2, 4 on the intake (two on each valve). You will use a 30mm socket and turn the crankshaft one full revolution (360 degrees), then take 2, 4, 6, (two on each) measurements and 3, 5, 6 (two on each) measurements.
5. Use a magnet and a tiny screwdriver to pull the shims for each. Basically, the cam lobes will move off of the valve buckets allowing you to get at them, pull them out, and measure them (use a digital measuring tool). FSM page EG-18 has the formula for figuring out the shim spec. EG-20 through EG-21 has the matrix for adjusting shim selection chart. Figure out which ones are in spec and out of spec, order the correct shim (you know who to contact ;) ) and then install everything in reverse order. Set your timing.
Good to go for another 100K or so.
Later.
-o-
hmmm... OK i will look into this. I replaced the valve gasket as well as the spark plug seals about 1 year ago. I hope they are still OK.
They will be fine. Go in an do the adjustment. I can guarantee you that your rig won't tick anymore.
If it does, I will fly out myself and re-do them.
Um...I think mine are ticking now..... :idea:
as always Onur, thanks for your assistance and willingness to lend a hand!!
So you are saying "if" i have a sticking lifter, a valve adjustment will fix it?
No, if you have a sticking lifter, you'll need to free it up.
When you measure the valve clearance, any sticking lifter will quickly reveal itself. The clearance will be much larger than the others.
Yup--what lacruiser said....as in significantly greater space than the other valves.
That said, I doubt you have a sticky lifter. I have yet to see a 1FZ have this issue. More than likely just need a valve adjustment, which would make sense for a vehicle with so many miles on it.
Mine are ticking, but I doubt you'd want to come back to this ice and salt encrusted, windy, wintry wonderland.:doh:
Rislone comes in a yellow bottle and you can find it in any auto parts store in the oil additive section. I would try this if you are just trying to buy some time until doing major work. I added a quart to my LC when I bought it a couple of weeks ago as it had a tick- all gone now.
Listen.... :eek: can you hear that... :eek: I think it is coming from the garage
TICK TICK TICK
I have an extra room for you Beno. :D
lol, you guys are a gas!
I think that an additive would have already made "some" difference, and it hasn't. I have had great luck in quieting lifters and valves with marvel mystery oil in isuzu motors. Didn't make a bit of difference in the 80. But!... i hate to try to even get the valve cover off right now. They are calling for more winter weather tomorrow, so the 80 will still be on duty.
This truck, by the way, is a dream in the snow!!!!
Right you are. I have seen Marvel immediately quiet some really gummed up lifters over the years. If it did nothing, then no additive is going to work. But it was a great shot, it's what I would have done first.
I have heard of Rislone, but never tried it. Probably very similar to MMO.
