Help, Header Melting Everything
Coating is on the inside, so there is a layer of insulation between the hot gas and the metal of the header. Wrapping is on the outside, so there is no insulation between the hot gas and the metal.
So how do you *get* headers coated?
Its not like you can just paint it on the inside.....
Just like you get stuff powdercoated- you take it to a guy. :D
-Spike
I don't have any answers but rather a question:
Would a partially plugged cat be the reason the heat is not pushing through? Or is it just simply a problem with the headers?
Buck Buchanan
Yes they are CERAMIC COATED.
Yes i talked to Man-a-Free service dept. They sent me here to this Board for answers.
AND as i matter of fact, The Gas Pedel mount melted off the first summer after i had the Headers put on.
I'm at the point now that our 92 Cruiser is realy PISSING ME OFF, Had her toooo long now, just dont have the heart any more to do what she needs.:shotts:
I don't think it's your cruiser, I think you happened to buy a poor product......from a company that doesn't support it's customers...
I just hope this info helps others in future purchases.......
.:beer:
Like i said, Just dont have the Heart anymore to do to her what she needs. Going to fab a Heat Sheild this week then get her detaled, Then put her up for sale.
Is the Downey Header for the FZJ know for causing similar problems?
:beer:
THE LATEST: Order up some Heat Shielding Sheats from HP Shield today. (ALMOST SPACE SHUTTLE STUF)
I also half to go to ACE Hardware today for Epoxy and some wire conectors to make the plug that plugs into the Alternator. The old one crumbled in my fingers as i unpluged the Alternator. WHAT A BI*CH !:doh:
To tell the truth, Its actualy alittle fun. But, it is getting old.:o
THE LATEST:
Went to Home Depo, Bought a sheet of Steel, Cutting, bending and Rivetting i made a 3 sided Heat Sheild. Luckly the Heat Sheild that i got from HD came in. Their Sheilds are rated at 2200 Degrees. Bent that thing up then mounted it in the Steel Sheild with screws. Got the Mean Green Alternator in then reinstalled the Air Pump. Had to make a new Alterntor power Plug ( i guess thats what its called). The old one went to peises in my hand.
Heres a pic of the Heat Sheild before i reinstalled the Alternator, Air Pump, Hoses and eveything else.
PICS TOO BIG, OK I DO IT LATER.
I thought " WHAT THE HELL, LETS SEE WHAT HAPPENS IF I LEAVE OF THE EXHAUST RETURN LINE "
Bought 2 Brass Garden Hose Caps, Capped off the "Out" on the Header and did the same to the "In" on the Manifold. My son fired her up and she runs like a CHARM :bounce2::bounce::bounce2:
Realy dont know if she runs any cooler, But with that HOT Exhaust Return line off and not putting hot air into the Manifold anymore, She must run some what cooler.:confused:
My Son took her OffRoading yesterday, No problems so far. She just needs a GOOD CLEANING inside and out.;p
pics of the heat sheild without the alterantor and air pump installed.
next is the exhaust return off and brass caps on.
Boy.....sounds like a header is a real wonderful investment for a LC.
Another vote to make this issue, and even mention Man-a-Free by name in the "tech zone" for things you want to avoid doing.
I'll tell you what the PROBLEM is !! THE 90-93 FJ80's are P.O.S.'s
Our Family Cruiser, the 96. is a FAR BETTER Cruiser than our off road 92 is.
You are so misguided. I weep for you.
Just let me know when your HG fails....
3FEs Unite...Wind, Fire, never mind.
