I straighten my engine that made 176,000 miles I replaced the radiator to the copper radiator. OEM water pump All the main water pipes to silicon including the pipes in Fire Wall and the small and annoying tube under the engine. Distributive covers and rotors, Ignition cables and iridium spark plugs. Engine mounts and gearbox. and all belts.
With two things I need help
1. There is a S like tube marked with pictures that can not find where to buy
2. Three connectors that are not attached to anything I can not figure out what they are. Are they origional? If yes, then they are ??
