Help from the 1FZE gods -
powderpig said:
So Tucker, The truck ran fine until it warms up, then it misses? Interesting, could be injector, or plug wire, crack in distributor cap. Did the miss stay at the same place when you installed the new spark plugs? Did you try to listen to the injector when it was warm to see if it was sounding the same as the others? Just some more thoughts for you to look at. later robbie
The miss seemed to be at the same place once up to operating temp - I'm going to replace the cap and wires to take that out of the loop and go from there. If I steal the little woman’s stethoscope will I be able to actually hear the injectors?
Tucker
New OEM cap, rotor, and set of wires this morning along with the new plugs from the other night and everything seems to be back to normal. I only got to do a short test drive, but it came up to operating temp w/o any noticeable missing. Hopefully it was just the crappy arse Bosch stuff -
Thanks for everyone's help!
:cheers:
Tucker
The Germans and the Japanese never really got along....;)
