Hey guys, here are my symptoms:
1) Both horn and hazard button doesn’t work.
- The fuse for the above burns out/pops the minute you try to put a new one in.
2) When I press on the brake pedal (assuming all lights are off), the running lights come on (entire dash and corner lights outside), as long as the brake pedal is depressed.
3) When signaling to the right, the clock light (brightness) on the dash, pulsates with the signal, and still pulsates at a lower brightness with the brake pedal depressed (for example when slowing down to make a right hand turn).
Any clues as to where I should start? There is a green wire (assuming it has to be a ground wire) that’s running underneath the trunk carpet (closer to the rear of the vehicle) that isn’t connected to anything. Should I start by grounding that first?
