I have not been chasing solutions to these codes with great vigor. They have been intermittent for a year, but constant in the last month. The car sees limited use these days, about 1 mile daily, but they are starting to drive me nuts!
- We don't ever see them running mid-grade or premium fuel.
- Tested the PAIR Valve as discussed in other posts, ok.
- Tested O2 sensors, 1 was fine, 2 I am not certain about. It failed the voltage test once, but after taking the connectors apart, cleaning with a fine file applying dielectric grease and replacing it seemed fine. Heater circuits tested ok.
- Did propane test on all vacuum/intake lines I could see. I missed the ones under the intake if there are any. Nothing remarkable except a split in the PCV valve hose which I have taped awaiting a new hose.
- Replaced exhaust down pipe due to leaks two years ago, no apparent leaks now.
- AFM(?) tested fine per FSM
- No noticeable miss-firing, engine idles more smoothly than my Audi A6, I mean stupid smooth.
- I replaced spark plugs and the light went away for a week (used to come on with 15 minutes of resetting). Used Toyota copper plugs, iridium ngk were in there from a prior service. Old plugs looked fine.
- High tension measured ok at about 25,000 ohms each.
We got excited....a bit
Then my daughter took car on 350 mile trip to go climbing in WV. CEL came on for 20 minutes (she did not pull codes) then went out.
Car got 13.6 mpg at 70 mph crossing some mountains on interstate highways, not too bad.
What next? Ideas?
What next? Ideas?
