Took my 84 FJ60 to a shop for a general checkup/inspection (reputable & recommended by some 'mud folks) and the guy suggested that I a carb rebuild (~$500) or replacement (~$1300) to get it running good (not running rich w/ fluctuating idle) again. He also said the emissions stuff is all
up and he says it's sending exhaust into the air cleaner - would that just be some clogged valves or something. There are no smog tests here so maybe I should just yank all that
out.
It had a carb rebuild by Mark's Offroad over in CA at around 208K miles and it has almost 215K now...there's no way it would need another rebuild inside of 8K miles, would it?
He also said the carb idle circuit is failed--is that the idle solenoid?
This thing had so much work done to it a couple years ago (2008/2009) that I find it hard to believe the carb & emissions is jacked up...
It had $1300 worth of emissions and valve work done in '09:
Recent professional valve adjustment, new valve cover gasket
New Intake/Exhaust/EGR gaskets
Help!
out. It had a carb rebuild by Mark's Offroad over in CA at around 208K miles and it has almost 215K now...there's no way it would need another rebuild inside of 8K miles, would it?
Help!
