HELP Blown Engine of '96
Dallas
Please help. I blew the engine on my '96 this weekend. Just got off the phone with the dealership and was told that a rebuilt is $9400 and a factory short block is $8400. I am devastated. I am looking around now for a recycle. Any other suggestions? The engine blowing is a complete shock she's only got 124k miles and is in otherwise excellent condition, I was told that the rods broke and the cylinder melted. I have used it as an everyday driver in Dallas and can't part with it, even if just to keep as a weekender....any affordable options. Thanks for your help!
check in the parts for sale section, there was a complete drivetrain for sale
Give Oleg a call
irbisoffroad.com
WOW
I think we ALL would like more details around the engine blowing. If it were another HG failure that would be one thing but complete engine failure/destruction? Any symptoms before the failure such as the PHH blowing, HG going, overheating, etc?
Call CruiserDan when he returns from vacation. He can line you up with a new Factory short block from Toyota for substantially less than $8400 (IIRC they are less than $3,000). Of course you will still need a HG kit and labor to install but maybe you can do that yourself.
There are usually a few engines and drivetrains for sale.
Places to try:
1. Proffits (they are doing 4BT swaps and may have some good 1FZ-FEs)
2. Slee Offroad
3. Oleg (see above post)
4. Cruiserparts.net
5. Classifieds here on 'Mud
No affiliation and no experience with any of the above for used engines.
-B-
run out of oil?
Depends what part of the country you are from if shipping is an issue. Cruiserparts on the East Coast usually has a few in stock.
Another one hit wonder?
I'm a newbie. Got the cruiser in 98 with 36k and has been an everyday since then. Last summer I had an oil leak and took it in. They replaced the rear seal and I still had a leak then they replaced the oil pan gasket. I was concerned about a pinging at acceleration, dealer said it was nothing. I must have been low on oil from the leak for a short time during the process but never lost pressure and I topped it off to make sure that I didn't burn it out. Had an oil change last week with a full synthetic. Was on the highway doing 65-70 and heard a loud noise and clacking sound. The oil pressure was normal but was dropping the temp was normal As I pulled over the noise was God awful and as soon as I got to the shoulder the engine stopped, when the engine/fan/coolant stopped the temp spiked and I got a little bit of smoke from the hood. Waited for 2 hours on the tow so I checked the oil once it cooled and it was 3/4 full. Had it towed (50 miles) on a flatbed and there was oil on the flatbed and the third member/transmission etc were slick with oil. Dealer told me that there was a radiator leak that overheated my engine he said that I bent and broke rods and that a piston overheated and dmaged the block (not sure if it fused or not, my head was spinning with the news). I live in Dallas, TX and the engine has never run hot. They said they were able to start it today but that it was making horrible noises. Like I said, I'm a newbie so I will leave the forensics to the pros out there, just thought I would let you know the full story. My concern now is what is the best route to go. I haven't found a used engine for my model yet but I've found previous model and later model so I am optimistic. I like the idea of a $3k block from cruiser Dan. If there is a reputable shop in DFW that could install I would appreciate the heads up. Sorry for the long post, I'll reply to the other messages as well. Thanks for the help mud haters.
hmm do you know if it pushed a rod out the side of the block or pan? (usually fist sized hole) that may explain the oil all over, a recent oil change makes me think of double gasket but 3/4 full of oil does not line up with that, time is too long anyway, usually a double gasket blow in much less than one day, not a week, though i guess one really well stuck could possibly make it a week.
The factory temp gauge is not responsive to overheats until it is well on its way but the gauge should have moved well before seizure,
by chance do you know what brand of oil filter was used? it could have collapsed internally. the techs would have to cut it open to find out. though that would show as a loss of oil pressure.
could it have had a miss? any codes ? was it running well before ?
You will be very lucky if the filter is collapsed internally. Some one else could get the bill.
was there any coolant in it?
which cylinder do they say is bad?
where on the block did you see oil?
how do these guys know it is seized and rods are bent, and how/why did they start it like that?
faint hope... if you blew the head gasket so a ring popped into a cylinder you would get a horribvle noise but possibly only minor damage tpo the cylinder. ask me how i know. if you blew the h/g at #1 I suppose it is possible the oil is coming from around the timing chain. that would be a much smaller problem
other possibility is cruiserdan's plug.
Exactly what I was thinking 'cept he said it was 3/4 full (6qts) of oil. That is 2 qts low but not enough to cause catastrophic damage.
-B-
that would mean that pesky oil light was on for one hell of a long time.
is it possible that his oil sensor was covered with gunk (or something) preventing this light from coming on?
