OME heavy lift all the way. Will support you in what you do now, and when you get the armor on. It will come with shocks, springs, etc. The ATL crew is pretty darn good at putting them on too, we are down to 1.25 hours start to finish on the last one I think![]()
Bill I think there is a skid comparo on the FJCruiserForums under 4x4/offroad tech section. Yeah, go here:
http://www.fjcruiserforums.com/forums/4x4-off-road-tech/15359-complete-skid-plates-comparison.html
Bill - here is the link to Sonoran Steel parts for the FJ.
Yes, there are some that have just welded a (for lack of better words) a ramp/support to the bracket. Helps make the transition when sliding on them so they don't get bent.
I know that All-Pro has introduced a new part in square tubing. Haven't looked at the part with any detail but just glad others are looking at this weak link on the FJ.
Heather what do you run?
umm, I am assuming you did the harness hack and not the addition of the button? Or the hack where you can ATRAC with rear locker?
If you did the plain ATRAC hack, you should have bought the $43 button and called it day.
Either way, if you messed with wiring with the battery connected you could have fried an expensive ECU or two. I can say that the ignition should NOT be in the same harness as the traction control...but I don't have a wiring diagram to help....if you have it so you can put it back to stock...do so, and call the dealer![]()
