I know the subject has been widely discussed. I have spent hours researching it. I'm looking for the best way to switch both front and back to disc. I have a 1971 FJ40. I would like to use the original riveted rims (as they have been prepped & painted) but realize that may not be an option.
Here is my understanding of my options:
Front:
FJ60 conversion--use this or truck front axle and then use FJ60 non-vented brakes. Are there other options here for vented?
MAF front kit--- Wildwood, this way I get ventilated rotors
JT outfitters: I've read that early on there were issues but that has changed???
Rear:
MAF or JTO rears. any good?
Posers kit: this appears to be the way to go. Use these brackets and go with Monte Carlo/compatible rotors/calipers.
Again, I'm looking for the most up to date info./recommendations. Ease of installation, dependability and parts are all important. I may want to add a OME 2" lift at some point. I also want to run 31's on original rims (rivet or weld).
Thanks in advance.
Front:
Rear:
Thanks in advance.
