help axle
The West
:cheers:hi everybody
i have a few questions here
i had gone with the h55f swap and have found that my cheapest e brake option would be a late style ebrake axle.
so my question is where do i find these axles. evidently they are hard to come by and
any help would be great. out here in the bay area labor is expensive and im running out of cash so maybe the eldorado calipers are out of the question for now. i want to keep things simple.
again any help or leads on these axles would be great
thanks alot
okie
- i have searched everywhere
Howdy! If you swap axles, then you may have to go thru the diff, do axle seals and bearings, and also a brake job, and hopefully the drums aren't warpped. Is that really any cheaper than going with the Eldorado setup? I' am getting close to doing this myself. I have the brackets, but I have not gathered up the rotors and calipers yet. John
yea i agree but i did some research on the eldorado and it looks like they are a bitch to get adjusted and mine is going to be a daily driver. i just can't throw down that kind of cash and never get them adjusted right. whats the point of even paying money for them if they won't work properly?
another thing that I have to think of is i dont have the booster or master setup . i have a 1970 fj with mini trick front disc already. labor around here is 100 plus an hour. its just crazy.
c what i mean? unless i am missing something
Post up in the wanted section that you need an 08/80 and later 40 series rear axle assembly.
Someone may have one.
Have you talked with George?
SOR shows the housings. I cannot imagine that Marv does not have a complete set up, minus axle shafts and diff, as you will not need them and can use your earlier axle shafts in the later housing.
Call MAF as well. Al may have something.
yea i will check them out. im not looking to rebuild an axle but if thats what i have to do it still might be cheaper than the eldorado setup
yes i posted also in the wanted section. because i didn't clarify i was not looking for the fj60 axles i got a good on a guy that wanted to sell me that set up . he was awsome its just not the setup i was looking for
thanks
So what are you using for a master cylinder with the Mini truck disc brake components?
i am running a 1980 master and a 1970 booster. evidently it worked before with the min truck disc brake setup.
Then there is no reason why you cannot remove the residual pressure valve from the rear circuit of the master cylinder you currently have and install the GM calipers....
i thought you had to have a more powerful setup though. don't most people upgrade their booster and master . thats what ive heard anyway. thats why i wasn't sure about that.
Eldo calipers are not a pain to adjust. They are automatically adjusting.
You are much more likely to need to adjust the brakes on a Land Cruiser drum.
Provided the parking brake and other components function properly, using the parking brake in the later trucks will keep the rear shoes adjusted well. ;)
:beer:
