Help, Aussie Rear Locker Install advice req.
Tierra y Libertad
In the middle of the Aussie Install. My buddy and I were having no issues until it came down to measuring the space between spacers and pinion shaft to verify we are within spec.
The numbers are .0015 and .006 on the other side. (should be between .006 and .020) I didn't order any side thrust washers...I'd like to get this done today.
What say u? would sanding the current side washers be an option? I was under the impression that most installs come within spec?
Are there any thrust washers in right now? (present already) are there more on one side than the other? If so, you may be able to take one from the "tight" side and move it to the "loose" side....
You want this to be tight as possible so sanding down to a larger gap to match isn't useful...at this point you need more material not less. It IS within range already but if you can find a way to make both sides .06 or so, you should. You don't want to open it up again. Do it right the first time.
After 20 minutes or so of sanding...Got the opening to .003 from .0015 (the other side is fine already at .006) keep sanding till we get it to .006 or we're good?
