help... 87 fj60 brake lines fittings sizes
Old line out...
Fixing my fuel system currently and saw this line that is not connected to anything. Is this pipe part of the brake assembly?
That newer-looking black fuel hose isn't stock. The open-ended tubing should connect to the tubing above it, the tubing that the newer-looking hose is attached to. That line comes from the charcoal canister. The tubing has been by-passed with the black fuel hose. Can you post a photo of the other end of the open tubing and one of the other end of the black hose?
This diagram might help:
Thanks this diagram does help after staring at it for quite some time. It seems this tubing was bypassed with the newer hose, also seems like it was done recently I’ll have to ask the gentleman who worked on the truck.
I’ve colored the circles for each hose. I’m still confused what I do with the green one.
The hose that’s in your green circle is the axle housing breather hose. It’s supposed to be lifted up high like that so it doesn’t suck in dust or water.
