Hello all
Idaho
Idaho noob with a recently acquired FJ40 (1970 F). After many years of admiring seasoned FJ40's, I finally found one. My cylinder head is at the machine shop now but the head rebuild is stalled pending exhaust valves (13715-60020 single groove 37.5*125*8*45 degree). Hindsight is 20/20 (I should have bought a recon head from an expert) but I'm already into the head rebuild (seats/inserts/guides) and can't find replacement valves. I have searched the forum and valve suppliers looking for a work around but could use some additional advice for on F exhaust valves. I have been unable to determine if I can use other valves of the same dimensions i.e.(60032/61010/61030). Could those valves be used if the corresponding double or triple groove keepers are used? Thanks in advance, jc.
Welcome! That part number shows up in stock here. 13715-60020
When researching exhaust valves for my 74 F.5 I come up with 13715-61030.
At ToyotaPartsDeal it also shows it as the valve for your 70 F. It's also the same for the early 2Fs.
That's what is shows anyway.
That's what I see also but as far as I can tell those valves use different keeper grooves. The valves I have are single groove.
More pics!
I've seen the muIti-grooved stems in pics of the after market valves. I only saw the hand drawn pic at ToyotaPartsDeal site but no photos. I wonder what the multi-grooves are for. Different keepers or, same keepers but for multi applications? Spring tension adjustment? IDK.
Here's a pic of the Sealed Power V2257 from Rock Auto. Same part number for F, F.5 & the early 2F.
Hopefully the guys here who rebuild them often will chime in.
