For Sale HEI Distributor - Calif.
Status
Not open for further replies.
Sacramento, CA
I recently switched over to a stock disti with Pertronix so I don't have a need for this distributor. It needs a gasket (doesn't use an o-ring). It worked fine but oil did work its way up the shaft. I dont think I had the right gasket and it probably could have been clamped down better. It worked fine other than a little oil working its way out the base. Im pretty sure a good gasket would do the trick.
$50 + the ride. PM if interested.
Thanks,
Josh
Status
