Heater question
Emigrant, MT 59027
Jan 1972 FJ40, just purchased. I have found these controls..... 1) flapper handle on unit itself 2) handle under the dash 3) H knob 4) V knob that doesn't move. First question, I have seen mention about multiple H knobs, is that when there is a rear heater? Second question, advise on getting the V knob unstuck? Third question, having the radiator flushed friday, should i do the heater core at the same time? Fourth question...... should there be a blower on this?
The flapper handle controls defrost, one H pull is for front blower, one is for the rear. V opens the vent inside of the blower, your cable might need a good soak or the door is jammed. the one under the dash is for the cowl vent. Blower is in the engine compartment behind the battery. Good Luck.
thank you
thank you
If you pull the heater, it’d be a good time to make sure your wiring is in order, cowl vent seal is in good shape and the drain hoses are not cracked. Remember to disconnect the battery first, there’s a lot going on back there.
