Where to start??? 1994 w/218K, The PO was DR and did not take care of this rig. The radiator is full, overflow bottle is at half way, the thermostat is new along with 3 hoses, belts are in good shape, the fluid is 50/50 (green) and new as well. #6 is taking water and the engine is due for HG surgery. Idles at 650rpm. Recent tune-up, oil, plugs, plug wires, cap/rotor, filters, and all the usual items were replaced with OEM Toyota parts.
So here's what's going on...The heater will work if you let her warm up in the driveway for 5-10 minutes, and then it's intermitent. It's like I have Auto-Climate control, except I don't have auto climate control.
If you jump in and don't feel like waiting 10 minutes then most of your trip will be with no heat and you are cold. Sometimes if you hit a big bump then you might get heat.
Here's the twister part.
If you decide to turn on the rear heat, you will get to see the temp gauge go just shy of redline and then come back to normal operating temp. It does this over and over again. And for the record, the rear heat is blowing cold air! Always has.
The rig runs fine, temp gauge is right where it's supposed to be with one exception, there's no heat, especially when it's extremely cold.
I have a good idea of how heating systems work in automobiles, this one is throwing me for a loop.
Any ideas???
