REAL TIME HELP NEEDED- heater issue or may may be joining h/g club
semlin
curmudgeon
Mod Emeritus
north of 49
ok pulled into a parking lot today and got a miss at low idle
did an immediate bubble test in the overflow tank and nothing
overflow tank level normal
noticed a coolant drip on the heater outlet hose on the metal pipe that runs along above the exhaust manifold heat shields on the passenger side. It is near the point where it meets
decide to limp it home
get about half a mile from parking lot and temp starts to spike. I am crossing one of vcr's busiest bridges at this point so I keep going up to the top of the crown at 10 mph by which time the temp gauge is bruied. I coast down the other side and pull over.
the temp drops immediately as soon as it is in neutral but still running down to below the normal line.
engine is not missing that I can hear.
i notice the heater is blowing completely cold and realize it did not start blowing warm from the point I started the trip.
I pull over and the overflow tank is full. call a tow truck. the rad is dry so far as I can see.
-now i'm home.
here is the kicker. I start a one week ski vacation tomorrow morning which requires i drive the cruiser loaded 500 miles through 2 mountain passes :doh:
could the small leak in the rad hose have slowly drained my coolant off? if so, is there any explanation for the lack of heat and missfiring?
could it be a blocked heater core
i am thinking I am going nowhere in the cruiser tomorrow am. I will count my blessings this didn't happen tomorrow on the highway somewhere
Did you happen to notice excessive steam coming from the ass end?
Run a compression test. That's the definative test result you want.
Wish I was in your shoes. (Going skiing that is)
You leaked coolant out and overheated it. Replace the hose and make sure there are no leaks, then test it out. Whenever you find a leak your better off to fix it on the spot or get a tow than try to drive it!
changing out the hose now. problem is i don't u/s why a leak on the heater return side would result in now heat and also why the rough idle which is what tipped me off in the first place.
When the coolant is low, the first thing you can feel that starves is the heater, at that point the motor is overheating. The rough idle was probably due to the overheating.
I've been in cars low on water that idled rough. Always assumed it was hot spots - hot valve causing preignition, etc.
I'd fill it up carefully and start it up to see what you have. If you damaged anything, it won't damage anything further to run it for a bit full of coolant. I suspect you simply got extremely low on coolant from the leak as mentioned above. What happens then is the heater core is no longer getting hot water at some point, so no heat. That's pretty low and not a good thing as at that point the head is also not likely getting water.
Start 'er up and watch the temp guage. Be sure you filled it with the heater temp full hot. I don't know why your overflow tank didn't get sucked dry, but guess it was because the leak was so much and so fast that the next time you shut it down there was so much air in the rad that the cooling water could not generate enough of a vacuum to pull in overflow water.
You'll now get bubbling into the overflow as air pockets get pushed through the system.
Idling OK, temp is normal? Take it for a short drive to see what you've got. Then post back. Don't panic - all may be well.
DougM
What he said and good luck. Hope you get to go on your trip.
How big was the leak in the hose. I'm curious.
I know you are sharp - but waterpump???
so how do you bleed the coolant system if it has some bad air pockets?
the bad hose is replaced and I did the t-stat while I was at it.
it made a horrible scraping clattering noise when I tried to start it that might have been the starter. never heard that before but it was like the sound when a starter engages when the motor is running. only worse. thought for a second it might be due to something tow driver did to tranny so I started it in neutral with t-case in neutral and it still made the noise. plus for some reason my alarm disarm tone started beeping periodically to add to the tension.
anyway, it did start when my wife turned it over with me with head in engine bay, albeit requiring more turns than usual. after warming up it starts normally and seems to idle smoothly but when i took it round the block it felt rough
it is full warm now but no hot air and maybe more exhaust smoke than usual. i am letting it cool to check and top off the coolant.
this sucks
I've flushed my coolant a number of times, and not had any trouble with purging the air. My driveway has a little bit of slope, and I park with the engine uphill.
As I fill the radiator, when it first gets full, I squeeze the upper radiator hose to help burp air out from that hose, adding more coolant as I do so. I start the engine, set heater control to hot, and let it run until the radiator just starts to warm, meaning the thermostat is opening. I shut it down, carefully crack open the cap with a towel. I add more coolant as necessary to fill the radiator. After that, I fill up the overflow bottle and check it after each engine cool down cycle, adding more coolant as needed to the overflow bottle to keep the level up to the designated mark. Each cool down cycle the engine draws less and less coolant from the overflow as the air is purged from the system.
I don't think, after a flush and initial fill of the overflow, I've had to add more than a quart or so in total to the overflow bottle before the level stabilizes. At this point all air has been purged.
My heaters have always worked with the initial fill of the coolant system, at the very first startup of the engine. I believe that doing the initial fill with the front of the truck higher than the back helps with the purging of air.
ok just remembered to move the t-stat jiggle valve to the top so i removed and reinstalled it. however, after refilling and bleeding as best I can it is the same story. rad is full, temp gauge si at the normal warm spot but no heat. But, if i drive it around the block the temp gauge moves upward..
Flush heater cores, make sure heater valve is open, and then I am out of ideas.
Is the tiny molded heater hose that is connected to the heater valve hot?
ok went back one more time.
none of the hoses I checked heated up until i drove around the block even though temp gauge showed in the middle. both the in and out rad hoses were soft
went around the block once it moved halfway to the red. the radiator in hose at top right stiffened up and it is hot along with the inlet side of the heater valve. the outlet side of the heater valve remains cold as does the heater return hose and the return hose from radiator to t-stat. the coolant in the overflow is bubbling like crazy and smoking.
i can see the heater valve cable working but it looks like the valve is not functioning. the heater and temp adjustment worked fine yesterday so i am confused. I may get up the energy to disconnect the valve and check it but I am currently pretty tired from working on it in the pouring rain and sleet today. the best way i can figure it a bad heater valve does not explain my overheating problem.
i am thinking maybe there is no pressure due to a rad cap failure? that or a blockage somehwere or bad h/g fasilure. I am not getting white smoke going up the hill so I am hopeful not but...
thanks for everyone's help.
I am seriously doubting we are taking this thing skiing tomorrow. We will have to get some snow tires for the subaru and repack everything a little smaller and the kids will have to sit on the skis. bummer.
semlin said:
...the coolant in the overflow is bubbling like crazy and smoking...
That's bad news. Sounds like worst case - head gasket.
didn't occur to me to think about the smoke. damn. is leaving it to sit for a week going to make things worse?
semlin said:
...remains cold as does the heater return hose and the return hose from radiator to t-stat. the coolant in the overflow is bubbling like crazy and smoking.
What do you mean - smoking? Steaming?
whiteish smoke/steam coming out of the overflow if I run it round the block. I figured it was vapours from hot coolant and the bubbles were because I clearly don't yet have a fully functional cooling system. it is bubbling like someone is blowing into it, not the occasional bubble I thought signalled a h/g. however, I am now considering another alternative.
No pressure?....You should have some pressure on hoses if the system is full and rad cap on. If you do not then it might be a water pump...
Can you see the coolant flowing across the radiator opening with the cap off?.. It should be noticeable movement after the thermostat opens. Don't open while it is still hot. Let it cool down add coolant/top off leave cap off, crank and see if you get the flow after the thermostat opens....
If you are reasonably certain that there is coolant in the cylinders you might take a look at what Doug did when his second cruiser blew the headgasket. He sprayed the cylinders with fogging oil before he left for vacation.
