Heater hose help
Amarillo, TX
Need some advice on replacing one of the rubber hoses that attaches to the rear heater under the front passenger seat (pic below). Unfortunately, the hose is not sold separately – it comes as part of the entire assembly that includes the hardline for way more money than I want to spend.
Local shop gave me a straight hose of the same diameter, but said he can’t put a bend in it, that it’s formed that way. I could get one from a parted cruiser, but would prefer new if possible.
Anyone know of similar part from another vehicle that would work? Other ideas? Thanks for your help.
I'd Try a piece of Gates Green Stripe or go silicone hose.
Constant tension hose clamps are best, but stainless screw type will work as well.
If you don't go with a formed hose I'd place a spring around the gates or silicone hose at the bend to keep it from kinking or collapsing. Is it possible to bypass the metal tube and avoid any tight bends? Is the metal tube there because it's in a spot where a hose would be vulnerable to heat, pinch, rubbing, or other contact?
I'm sure you've been up in the spot where the hose is which you are replacing. Did you thread a new straight piece in there yet to see if it will work? It may take the shape you want/need over time, and just require a slightly longer piece than the original. If there's no rubbing or interference type issues, I would go that route. I have a strong preference for OEM constant tension hose clamps, I think they are a good value and last decades. However, IME, the hoses we buy at auto parts stores to replace OEM hoses are typically a slightly larger OD than the original and you may have a hard time finding a suitable Toyota clamp. I have bought clamps on Amazon based on the OD of the hose I am using and been very happy with them. Check out my post here:
Rear Heater Soft Lines - PITA. Tips?
Good luck. The PM you are doing is time well spent, though it may be a PITA at times. You are solving exactly the kind of problem which is easy to ignore and easy to cause you getting stuck in BFE without cell service. Good luck.
Thanks everyone. I haven’t tried to fit the straight tube underneath, but I have bent it to match the contour of the original part. Pretty sure it would compromise the flow of coolant. Probably a cheap hose, so might not with one of better quality. Based on the input, I think I’ll explore the Gates route. I’ll post a follow up once I have this sorted out. Thanks again for the input.
