Heater help
Ohio
i have a '76. the heater box did not have the "control arm" whem i bought it. i found two fj s with control arms intact. i brought one home only to find out it doesn't fit. the control arm i aquired has one hole/channel on each end and on screw hole in the middle for attachment. the heater box in my fj has three "pins" and a screwhole for attachment. simply put the "new" control arm doesn't have the hole for the third "pin" on my box. my first guess is that my box is not original and/or not out of a 40(another toyota?). i've been to SOR and can't find a heater box like mine. thoughts? advice?
i've aquired the rest of the heater box which i removed the control arm from, but my box is in much better condition. therefore i would rather aquire the proper arm for my box if possible.
This is the part where a picture comes in mighty handy.....;)
Well, the one on SOR is a little different than the one that came in a '76. Here's a pic of the heater that I pulled out of my '76, has a 2 piece control arm, a square bracket spot welded to the bottom of the heater and the multiple attach points on the upper control arm like you are describing. Is your setup like this?
Here's the heater in my truck now, one control arm.
You could probably use the one piece arm of you remove the lower arm (outlined in red), all the holes should line up (blue arrows), and with the lower arm removed, the middle attachment hole will not be necessary.
If that don't work, shop around or post up in the Wanted section, somebody is bound to have what you are looking for.
S/F
Kush
