Heat riser block off plate
  • Thread starter Thread starter Deleted member 159334
  • Start date Start date
I bought a timing light from autozone that has a tach in it it works great. It also has timing advance on it so I can check timing on the tdc mark or use a different setting than stock if needed.
I will head there tomorrow....need to get this right
I think I need to get one isn’t a multimeter ....a dedicated tachometer. Know of a good one?
I just have a cheap-ass auto parts store one permanently mounted on my steering column. Works well enough for setting idle and driving.
That looks cool
Here is my timing light. It only has settings for 2-4 cycle.
Thanks....I’ll pick
one up this weekend
Anyone know where the block off plates can be ordered from? I'm searching for one for my 78. Thanks!
I run a block off plate on my rig, you'll need to trim the flapper inside or remove it all together. I think that in the winter it may need choked a little longer before it starts running as smooth as it should. Other than that I haven't noticed anything unusual.
Did same as Ryan. At a mile high here in Prescott and cold winter temps in the AM I may run the choke a little longer for her to warm up but other than that runs excellent. It would be nice if someone made something modern that would open and close the flap based on ambient temp. I guess they used to have something made of wax that controlled it. I am an analog guy but even to me that seems primitive.
You can find out more about them here:
So played around with the long bolts on the manifold and got it to lay flat on my shop counter....I had to drill out the other two smaller fasteners that rusted out and when I tapped the wholes I screwed up one of them and it threw things off a bit. I will just put a longer bolt though the one and torque it down with a nut. Should be ok....I bought a new intake manifold from Specter because they had one and their graphite intake manifold gasket. Should be able to get things back together this weekend.
Erik, getting the surfaces flat was a matter of loosening the bolts and shifting things around basically? Mine just came from the machine shop and I’m debating getting this block off plate since it’s all out of the vehicle
