So I've had some exhaust leak and finally got my gaskets together today, ripped out the manifolds and discovered that the heat riser butterfly isn't there. I searched, but the answer wasn't that clear to me. The leaks were from the heat riser gasket and th emanifold gasket. I've been driving for 4 years with no heat riser wondering why the fuel in my carb keeps boiling.
I would like to block off the heat riser with a piece of metal. My idea is that aluminum is better than steel, nothing to do with heat transfer because due to proximity it is going to happen anyways. Aluminum is softer and can conform to uneven surfaces better. My intake is in perfect shape, but my exhaust manifold is corroded to the point where no surfaces are even (besides the ones to the head).
SO what the hell do you do? Do you take a thin piece of steel, place it over the gasket, and sandwich the whole thing together? Or do you take a piece of soft metal the same thickness as the gasket, braze it to the manifold, and hope for the best? (assuming I can clean up the surface well enough to remove all the flakes of rust). A copper sheet would be ideal in my mind, but I don't know where to get that.
Suggestions? Would using the gasket and a piece of block off metal cause too much misalignment of the manifolds from it being too thick? This is the earlier manifolds (1968 hi-po/ normal exhaust on an f145).
