heat core replacement question
NJ
I am in need of a new heater core, not sure what option is best. MY '92 - Toyota no longer supplies many parts, so i was wondering what you would do?
Autozone - i see has one listed
landcruiserparts.net - has used one according to their site (says leak free)
have existing core fixed at a radiator repair shop (i don't know of any - would have to find someone)
Are there other options i have overlooked?
Try and PM beno, you might get lucky, he may have an NOS one in stock.
In any case, for me pouting and used 25 years old radiator is not an option it is a time bomb
@beno suggested a valid e solution that can work, but I don't like it either it is adding 2 week point of the 2 rings connecting the new pips to 97 radiators to new pipes (no part number for the OEM Orings)
You have 2 options for the radiator OEM (very expensive) or aftermarket
this link https://www.autozone.com/cooling-he...ter-core/526285_0_6064?CJPID=4022106&cmpid=cj is according to what is written is wrong part for apllication its for the rear heater
There are others for the front
@beno suggested a valid e solution that can work, but I don't like it either it is adding 2 week point of the 2 rings connecting the new pips to 97 radiators to new pipes (no part number for the OEM Orings.
I’m not sure you have any idea of what you speak.
But proceed nonetheless.
What I’m stating is that you are talking out your ass.
Do some research and come back with real information when discussing OEM Parts.
Your current track record is poor.
ok @beno start eating you hat
this is the old heater core both pipes ( in out) are connected permanently
the new one comes with disconnected pipes concocted with Oring
Desert Dino, i did see the quoted thread, but did not feel anything conclusive came from it:
That's what happens when you don't use search
new heater cores dont look the same as OEM?!
After review, i also find that the part that comes up on autozone is not right, as stated it appears to be the rear heater core.
So the consensus is to use a 93-97 heater core with [new?] pipes? I see you stating there are o-rings, does that mean the pipes connect in a different manor (not soldered)? So just confused there - do i need pipes from the '90 - '92? or ones specific to the 93+ (if i go with a core from the newer years)?
Sorry guys, i did try my best to search. I have only had this rig for about a year so i am not as familiar with it as many of you.
Correct.
And as stated earlier the later style situation works in the earlier setup.
The oring part numbers are indeed available.
Whether you like the solution or not, it would be the correct solution if you wanted to stay OEM. As stated earlier.
Wanted to get this in as well, regarding the newer heat core and the pipes. Which pipes would i use with the newer core? I damaged one of the pipes when removing my original unit.
@whitewhale To replace LC 93-96 front heater core with a new OEM LC1997 HC
UNIT SUB-ASSY, HEATER RADIATOR 87107-60270
PIPE, FRONT HEATER RADIATOR WATER 87248-60650
PIPE, HEATER WATER INLET 87248-60660
And maybe the firewall rubber grommet
87128-60010
90480-31007
@Desert Dino , I really appreciate the parts list! Thanks very much.
Now i am not sure - will this work for a 1992? I have read there is some difference with the '92 but the schematics you posted look awfully similar.
How about.....
A step by step walkthrough to replace the heater core in a FZJ? Maybe something with lots of pictures? For those of us that are...a little timid about taking the entire dash apart???? Pretty please??????
