heat core replacement question
@Izzyandsue, damn how did you stumble on this dealer?? I reached out to them. Expensive part, but I really don't see many options. I would love to know if the newer ones fit. I seem to recall reading in another thread that they don't.
I dont know much, but I do use my friend Google and his sister Bing. Finding the part number was the first step, could be easy but most "purists" make it difficult to channel you into their world. But with the part number I check overseas first, like Partsouq.com, since they typically have a lot of stuff not found in the US, or often a lot cheaper even with shipping.
Then just googled the part number, like "toyota partnumberwithoutthe-sign", and it comes up.
Discontinued doesn't mean it can't be found, just means the OE part is not required to be made by the OEM. Most automotive supplier agreements are the life of the program plus 12 - 17 years. In the later years, the tooling gets old and worn, manufacturers move on to new programs where there is more money, etc. And if the OEM decided to continue to make the part they will have to pay out of their own pocket for re-tooling, etc to stay in tolerances. Just economics, and engineering decisions where I spend my professional life.
So there is always a stock of parts somewhere, not always in the US. And as supplies dwindle, it gets pricier. That heater was around $340, the new version was around $290. But, will last you another 20+ years.
@Izzyandsue - unfortunately just as all dealerships tell you this one is the same. "Part is discontinued". So back to the drawing board. But that dealer is great for schematics. I have the FSM for the rig, but heater core is not detailed there.
@Desert Dino or @beno - do you have any insights whether or not the suggested solution of using the 97 core would work in a 1992, i see the comment from @Desert Dino - "To replace LC 93-96 front heater core with a new OEM LC1997 HC "
@Desert Dino - thank you very much for the valuable and honest feedback. I am tempted to try it because the parts look very similar. As long as the new core fits in the heater box and the pipes pass through the firewall i would be good. But those are 2 BIG *ifs*. Only other option i see is a site like cruiserparts to get a used core. But its not the best feeling putting the entire dash back together with the used part in there. Would much rather have a new one.
@whitewhale I did a lot of reading and there should be no problem with 1992 using LC1997 HC
Here is a pic I picked on MUD
Original (discontinued)
The new 97 HC style (the one in the pic looks like aftermarket)
Pics are from @BlueCruiser84
For the HC core you have 2 options
OEM
Or aftermarket
APDI 9010487 Heater Core | eBay
For the connecting piping you have 2 options
Bay new OEM 97 HC pipes
Or
Use the one on your old HC if they are in good condition (go to a radiator shop and let them solder it to your new HC) many mud members report that this is what they did
