headlight problem
El Paso, Tx
So I out my new head lights in and I have projectors for low beams and I have led for the high beam. After I put them all in the headlight both come on when I turn on my headlights. Does anyone know what maybe be wrong and I just had my engine replace could that have anything to do with it? any help plz
Some more detail on exactly what you installed would help. Where did you get the lights? Brand? What do you define as a "projector"? What did you use for instructions? Is your electrical system modified? Why did you mix the light types? It could be a hundred different things if you don't help us narrow it down.
it was
I would be extremely surprised if you got those things working properly in a 62 without doing 3 backflips in the wiring dept.
OR AT LEAST DOING 3 RELAYS BETWEEN THE SWITCH, BATTERY AND THOSE LAMPS....
Exercise the search box in the upper right corner of your screen. type in "negative switched headlights" or "h4 conversion" or "hid headlights". check out this thread....Headlight wire harness FJ60 and FJ62 Much info about the wiring system being negatively switched and the limitations of this system. Also problems with the thin old wires not being able to handle the amp draw of some new lights. H4 is a common upgrade. Beyond that you will have to upgrade and modify your harness.
here is my harness diagram...
use BIGger wire than you think you need. voltage drop = dim lamps. I pulled a #4 ground and hot leg to my relay sled(located at the ABV on the drivers fenderwell) then from the relays, I ran # 12 hot and ground to each individual filament. even the stock lamps are BRIGHT.
my relays are rated to 40 amps. if your lamps are high enough wattage, you may want to add a second GROUND RELAY in PARALLEL and use 1 GROUNDING relay for each bank of lamps grounding...my stock lamps draw 55 watts a piece- that is 110 watts PER BANK at high output, or 9.1875 amps per bank at 12 volts(less amps if the engine is on and the alt is bumping 14 volts). My overall amperage drawn thru the grounding relay FOR BOTH BANKS is about 19 amps max at HIGH HIGH output, so my 40 amp relay is plenty. I keep 3 spare relays in the center console and I'll never have to worry about being in the dark...well, while driving, that is...HTH
