Headlight glass replacement methods
Houston Tx
So a have a hole in my 94' 80 series headlight and am wanting to replace the glass. After an hour of searching, I found very little info on how the heating method is used. I have heard of using a heat gun or placing the lamp in an oven but can't find any info on the topic. Toyota sell the glass seperatly so there must be a way.
Now when going back together with it, what kind of adhesive is used? Anyone out there know of a thread for all of this or what?
Thanks in advance.
I would buy a used headlight assembly for a 94. Check the classifieds here for someone parting one out
"Toyota sell the glass seperatly so there must be a way.
Now when going back together with it, what kind of adhesive is used?"
Not sure who told you this but Toyota doesn't sell just the headlight glass. Your options are just the headlamp which is glass and case. Or buy the headlight assembly which includes the bulbs, case and upper and lower trim pieces.
I know because I looked into it and went with the headlight assembly.
Like Romer stated, if you don't want to go new look in the classifieds.
Peter
i wouldnt use a oven, I would think it would deform the housing before it heated the glue up. I replaced just the glass on mine. The way I did it was to use a heat gun. Heat up the edge of the glass, and it will soften the grey glue. Pull the lense off and heat up the glue on the old lense and pull it off and save it. Then heat up the crack in the housing where the lense sits, evenly distribute the saved glue into the crack, then once the glue is all soft in the crack, put your new lense in and your done. You wont need any more glue for the job if you saved it all. I did this method to my Cruiser and a buddies Rodeo and it works great. Take your time heating the glue though, it takes a little while, I just used a small screwdriver to gently pull up on the lense while heating.
If the hole has let a lot of moisture in, the reflective material in your headlight may have faded and will not give off a good light pattern. I fixed my headlight using an oven and the same glue method as stated above. I was unhappy because the light pattern was blurry and not very good. I ended up finding a lheadight here on mud.
