headlight comparo
Grench, where have you read that the drivers side headlight is supposed to be aimed lower than the passenger side? Everywhere I'm looking says they are to be aimed level with each other.
This is what I was thinking of.
Per Popular Mechanics.
Saturday Mechanic - Aim Your Headlights - Popular Mechanics
Effectively weighting the left light visibly down and right. I'm not 100% sure this applies to our headlamp housings. Does anyone have an FSM handy?
Mine just says to make sure the bubble for vertical adjustment is centered. And the red mark for horizontal adjustment to be centered.
Those bubbles are really cool, but I found they were way off in my truck. Same for the center line marks.
Agree with not using the bubble things. They'll get you close if you've had damage or changed the suspension, but then you've got to use a garage door or similar white surface to fine tune.
And yes, the driver's side beam should not go down the road as far as the curb side beam to reduce glare to oncoming drivers. Very important if you have HIR or other higher output bulbs.
I am so tired of HID retrofit crap kits. Factory kits - no problem. "Look at me, my 15 year old Nissan Stanza looks just like a new BMW 5 series now" crappy blue lights - big problem.
I'm sure there are good kits out there, but they're too expensive so all we see on the street are the crap kits.
DougM
So to summarize Doug -
Bubbles to get in the neighborhood, then fine tune with a garage door. Left (driver) side should be slightly lower than the passenger (right) headlight.
How do you know what the correct elevation is though? That is the problem I still don't understand. What is too low, too high, etc?
Yeah, I hear you. I'm extremely anal about the lights on my vehicles and have been for over 30 years. I use the left to right adjustment properly at night - observing the effect on my 3 stall white garage door. Then I use the horizontal adjuster to its recommended setting and go drive around the block a few times in the dark. Come back and make a few slight adjustments intended to move the blobs of light into the most seamless and useful areas out on the road I can.
All this is done with some gear in the truck and a full tank.
Then I uncork the big Hella fog lamps and use the final position of the low beam blobs to be sure I am hitting below them. Job is done until next big trip. During the trip I notice how the beam patterns help or hurt my*visibility, if vehicle bouncing causes problems, if I get flashed. Arrive home and address these final items.
DougM
