Headlight bulb question
Southwest Georgia
Ok so I have been reading a ton of posts about headlights, LED's, HID, HIR, etc. I am really unsure of which way to go. i know a large part of it is money dependent, but my main question is all that expense really worth it for certain options. I have seen some pics of the HID lights at night and they look awesome but this setup sounds more complicated than I want to delve into. i would prefer to be simple and not have to change out too much stuff. Also have seen some writups praising SLEE's light harness upgrade and I have seen several threads noting it did not help much and just introduced extra failure points in the system. So my main question is - from the guys with personal experience or who have tried different options - which headlight method seems to be the most bang for the buck without making the system too complicated. I prefer to keep it simple instead of messing stuff up with redundancy.
BTW its a 1996 Toyota Landcruiser
Some options and prices:
1)Standard 9005/9006 - Sylvania Silverstar - 9005=$29.99 for 2, 9006=$29.71 for 2 =Total $59.70
2)HIR 9011/9012 - Philips - 9011=$22.95 for 1, 9012=$22.85 for 1 = Total $91.60
3)Ebay LED 9005/9006 - Unknown Brand - 9005=?$61.99 for 2, 9006=$55.79 for 2, = Total $117.78
4)Lifetime LED 9005/9006 - at Southeast Overland - 9005=$149 for 2, 9006=$149 for 2 = Total $298
Here are links:
Sylvania 9005: http://www.amazon.com/SYLVANIA-SilverStar-Performance-Halogen-Headlight/dp/B000M5W25E/?tag=ihco-20
Sylvanis 9006: http://www.amazon.com/SYLVANIA-SilverStar-Performance-Halogen-Headlight/dp/B000M5Y720/?tag=ihco-20
Philips 9011: http://www.amazon.com/Philips-9011-Standard-Headlight-Bulb/dp/B00480J5CW/?tag=ihco-20
Philips 9012: http://www.amazon.com/Philips-9012-Standard-Halogen-Headlight/dp/B00480N18G/?tag=ihco-20
Ebay 9005: http://www.ebay.com/itm/4000Lumen-9...Parts_Accessories&hash=item1e99c8074b&vxp=mtr
Ebay 9006: http://www.ebay.com/itm/9006-HB4-He...Parts_Accessories&hash=item35d916f20b&vxp=mtr
Lifetime LED - Southeast Overland: http://www.southeastoverland.com/in...t_id=343&virtuemart_category_id=114&Itemid=33
Thanks for all the help. Thought the links might help other people who are interested.
Here's the vehicle since we all love pics
I removed my comments about the DEPO upgrade. I figured the OP was interested in bulbs, not headlights.
As for the SLEE harness: If your stock wiring is in good shape you probably won't notice an improvement (this was my situation). If your stock wiring is compromised, the SLEE harness is going to help out. Regardless, the SLEE harness is an improvement in design.
I have:
1994 with SMS harness and 9011/9012 HIR's from candlepower. That setup was about $300 and gives very good light, my 9012's need to be replaced though as they have started to dim after 2 + years. No, I do not know if the SMS harness helped as I don't have any before and after comparison, I did it all at once.
1997 with Wagner brand 9011's in all four slots. This setup puts out very good useable light and is much better then the silverstars that were in it. This setup cost me about $50 and a couple of minutes with an exacto knife and butane torch ( there is a tab that needs to be altered ). This will not give you mind blowing lighting. It will give you a very clean white light on low and good projection on high. If I needed more light then this for driving on road then I would switch to HID.
note: the Wagner 9011's are about $12 on rockauto. They are rebranded Philips bulbs that are made in Germany. You will need to do a search for a vehicle that has them, I think I used a 2000 BMW Z8. They are 65w high beam only bulbs, but as I mentioned they can be modified to fit in the low beam slot. They only have a 300 hour life expectancy, but for the price you can buy some spares.
I just got a set of HIR hi/lo bulbs from candlepower (they are bulbs 9011/9012). Great customer service and place to deal with. They have a special right now for all 4 bulbs for $90. I have them connected to my slee upgrade harness. I'm impressed with the output difference over stock wiring and 9005/9006 halogens. They aren't blue/white (so if you want that look, look elsewhere). IMO the color is perfect for my 20 year old FZJ80... I think the blue stuff looks cheap. I also adjusted the angle of my lights up a few degrees (I just added new ome suspension and have a slight "down" angle when my rear cargo isn't fully loaded). Adjusting the angle makes a huge difference. There's a great post on headlights in the FAQ threads (its a bit oitdated but a good read IMO): https://forum.ih8mud.com/threads/faq-80-100-series-headlamp-and-auxilary-lights.11932/
I also
I also have the slee aux harness and OEM style switch that controls 2 rigid D2 LED driving lamps. The rigids are pretty inconspicuous and are great when offroad or for driving on some of the small windy country roads through wooded areas (these are literally a life saver). 2 nights ago I was up near Gettysburg, PA in the middle of nowhere (with all the crazy winter storms), and those rigids are amazing. The HIRs just weren't good enough in those conditions (any headlight setup wouldn't have been). I should have taken some pictures. If I get a chance I'll post some up here. Hope this helps.
I have a new-to me 80 and have upgraded to 9011 & 9012 bulbs from Candlepower. I live rural and it gets very dark where I live. These bulbs are a huge improvement over the ones that came with my rig. I'm extremely happy. Candlepower has great customer service. No harness here, just the stock wiring. $90 well spent.
I just ordered the candlepowerinc set for 90. I am going to stick with the factory harness for now. If I ever get lights for the arb maybe I'll get the slee harness then. Thanks for everybody's help. I appreciate it.
I bought some leds off eBay that just have the heat sink without the fan. They are phenomenal and were only $55. Although the manufacturer is completely unknown most of them use Cree leds and have a warranty. Just make sure they ship from the US.
Bump...any new recommendations? I need better light output and I want to get away from the yellow headlight look. HIDs are out unless someone makes a projector housing.
$35 eBay LED low beams (Chinese with fans) the seller was local to me in Ohio so I gave it a shot. I am very pleased with the results over the oem halogen setup.
I can post photos once my phone is operational again.
I also added two Kawell LED spotlights where the indicators were on my ARB front bumper. These work great as DRLs and spread a beam low and a little wide.
