headlight/ammeter problem
Vancouver (not BC), WA (not DC)
The other day while installing a header on my rig, I touched the wrench to the hot wire on the alt. It was a quick touch.
Spark, oops, disconnect battery, move on. Now my headlights will not turn on and my ammeter does not register. All my fuses are fine. My only other guess is the voltage regulator. Does anybody have any other ideas?
Thanks in advance,
Kyle
Yes, everything else works. All other gauges work, all other lights work. When I started up after the header install, I noticed the ammeter not working. I checked fuses, and nothing was blown. Later, I pulled the headlight knob, and nothing happened. That is why I'm kind of stumped. It started after I installed the header. Everything worked fine prior. As I said before, I touched the hot wire on the alternater and it sparked. That was the only mishap. I'm pretty sure I didn't unplug anything else when I disconnected the battery. I guess it could be an electrical gremilin that just decided to show up after the header install... but as I said, I'm stumped. Any help would be appreciated. Thanks.
Just a guess:
I could imagine that the amp meter could be damaged by the short, but the headlight problem is coincidental. Does the amp meter work in one direction only.
For the headlights do the bad circuit drill. Start at the headlights with the switch on and look for voltage with a meter or test light. If there is no voltage, keep working back to the next point in the circuit until you find voltage and then the problem lies between the last two points.
Thanks for the response Pin_Head. I've been out of town for a few days.
No, it does not move at all. It is pointing about halfway between -30 and 0. It does not flicker with the turn signals or anything. Does that mean that it is fried? Time for a new gauge? I have not had a chance to dig into it at all since I posted this.
I'll get to this when I get a chance. It's not a daily driver and I don't usually drive it at night anyway. Besides, I hate dealing with electrical issues. I'll probably put it off until I have to take care of it... Besides, why do today what you can put off until tomorrow!:D
Thanks again for the help,
Kyle
