HEADERS?
East Tn
I have a 05 GX 470 with a bunch of miles, 383,000 to be exact.
Still runs and drives great but once again it has developed an exhaust leak at the manifold, this makes the third go around on cracked manifolds so I'm contemplating going the header route this time instead, it needs new exhaust anyway .
It's my hunting rig and serves the purpose quite well so I plan to keep it for the rest of its /my life.
Mods so far are
lift / shocks
wheel bearings, seals tie rods, control arms etc.
E locker from a later low mile 4 runner
reworked the AC completely
new dash cover
bumper/ winch
I've had this rig for 20 years and don't plan to part with it any time soon, so I want to do the exhaust right.
Headers are a great mod. They really wake up a VVTI 2UZ-FE and substantially increase mid-range torque. The increase is even better if you pair them with a cat back exhaust.
I installed a set of Doug Thorley long-tubes on mine in 2021 and they have been great, other than the fact that the collector gaskets seem to fail yearly ($10 part from Lexus so I just replace them). Unfortunately, GX headers are no longer made by Doug Thorley. Brockett Built now appears to be offering them, but they are quite pricey. They are a worthwhile mod, but they are expensive and very difficult to install (20+ hours of wrenching for me).
For fun, I've been AI-ing whether modifying mass-market V8 headers (e.g., Chevy LS) can be mated to our 2UZ.
Why? OEM manifolds will crack again (ask the OP of this thread) and aftermarket options for us (Thorley - maybe they're planning on another production run? + Brockett) are frikkin' pricey (no disrespect to running a small business and pushing a low-volume product, I get it).
Approach (I deleted my original AI chat...these are just the basics):
  1. Source <$200 headers on FB Marketplace/CL/eBay. From memory, an LS block's headers were spaced ~6mm further apart (CoC) than what our 2UZ needs.
  2. Remove LS header flange.
  3. Buy 2UZ OEM gasket + compatible flange (or CNC a new flange).
  4. Alter LS primaries spacing to match 2UZ exhaust port spacing/flange needs. Attach to 2UZ-compatible flange.
  5. And then....ensuring the secondaries/collector all route down through the engine bay and can be accessible for the rest of the exhaust is probably its own headache....or maybe not.
Even if it worked and can be routed successfully, it's still a header job. Many here know this is not a basic DIY job.
I'm not "that guy" who has the time, skills or equipment to do this - it was just an entertaining thought exercise.
But the topic here was HEADERS - so there's that.
They allow road hunting in East Tennesee?
Mark...
I'd say if you are on your third cracked manifold to look into engine coolant temperatures and figure out what's causing that. The 2UZ might be known for blowing an exhaust gasket now and then but not many reports of cracked / multiple cracked manifolds
>> Where is it cracking ?
>> Have you been replacing with OEM or are the past failures on aftermarket ?
The Doug Thorley headers mentioned above seem to have a solid rep, I didn't realize they are NLA
@Rednexus you mentioned no longer available for the GX. Curious if GX exhaust is bent differently than 100 series. I never thought to look too close
Here is a pic of mine from 2021. I think the tube routing and collectors are totally different than the 100.
EDIT: Looking at DT's website, they say the headers are "Back in soon"! $1,329! Interesting the price increase since 2021 when I bought mine is basically equal to the 30% inflation we've had (depressing....).
