Head install question
Boise, Idaho
I am putting a supercharger on my '97, and pulled the head for a refresh and to replace the head gasket as part of the project. IT's all gone pretty well so far, with the exception of a couple of broken sensors. Anyway, getting ready to install the head. I have two questions. First, should I wipe down the cylinders with motor oil or anything, as they look pretty dry.
Second, in the old days, mechanics used to spray paint the head gaskets with copper paint prior to installing. I think this was mostly on the all steel head gaskets used on cast iron blocks and heads, but should I be treating the OEM gasket with anything as part of the install?
When I did mine I wiped down the cylinder walls with engine oil, as I rotated the crankshaft . I did my best to clean out the carbon gunk at the top of the cylinder bores . I did not use any copper on my HG , the FSM did not call for it .
How are you able to deal with the timing chain while rotating the engine? My timing gear is currently ziptied to the chain at TDC.
Cylinder walls get "dry" when the engine sits whether the head is on or off.
I wiped the cylinders with an oily finger because I could, but who knows if ultimately it makes any difference. Certainly doesn't hurt.
HG goes on dry.
Pull the gear for timing chain after you marked it, then hold the chain as you rotate it for piston cleaning
Do not use copper spray, your OEM gasket will have a sticky silver grey substance on it already.
Do not scrape any carbon from the piston tops or cylinder ridge.
Use a little motor oil on your finger or a rag and wipe what you can see of the wall and call it good.
Because you wouldn't want to risk getting any of that crap caught between the cylinder bore and the piston. Especially not for whatever little gain you might get out of it. The time to clean piston tops is when they are completely out of the bore.
You scrape all that s*** off, then put oil on cylinder wall rotate them up and down and wipe it till all carbon is out from the walls that's how we would do it, once cleaned and no carbon on the walls you place a rag or cardboard cut out over piston keep it clean
