Okay, I have replaced my push-rod cover gasket and still have an oil leak
. It looks like it is coming from either the head or the timing gear cover
. The oil is appearing at the front of the block behind the timing gear cover at the level where the head meets the block and than trails down the right side of the motor. Can a head gasket go bad leaking oil out onto the block? Or does this sound like a cracked head? No oil in the coolant and no coolant in the oil, no smoke, starts right up cold, power is, well its a 2b with 33's, so I guess power is okay.
Thanks
Kris
. It looks like it is coming from either the head or the timing gear coverThanks
Kris
