head gasket question - case closed
Arizona - PHX area
Forgot to search first - disregard
Getting ready to re assemble the engine and laid the head gasket in place. It matches the image from the toyota parts web site, but it will cover some coolant holes present in the block. This is a non usa engine ( 1982 FJ45).
Options -
1. Do I have the wrong gasket
2. Can I cut holes for the missing collant openings
3. Use it as is.
Thanks for any suggestions
OEM gasket? it should have a tab that goes to the rear
make sure it is on the correct way for the oil passage feeding the rocker assembly
Hi - it is not OEM.
I was able to find multiple images from OEM and other manufactures, and the lay out is identical.
The gasket ( with tab at rear of engine) only blocks off a few coolant holes on the non lifer side of the block
Do the holes in the block that are being blocked by the gasket, have corresponding holes in the head? Some holes may be for machining only and don't match the head. It was also discussed "HERE"
Thanks Steamer that link is helpful. I triple checked, and the gasket I have matches the OEM exactly . I did find a few one sided holes ( ie the casting aids )
