Hello thanks again to all. I have not checked for a warped head or block. how can I check this?
Aye, there's the rub. You need a machinist's quality straight edge to get a really accurate reading.
To find out if you're even in the ballpark, an industrial quality straight edge, like a NEW, undamaged framing square or bullet level will be helpful. Lay it front to back across both sides and across the middle. If it rocks on the block, you're probably screwed. If it doesn't rock, then take a feeler guage and see if you can pass it between the level and various parts of the head and block.
Once you've tried both sides and the middle, front to back, then lay the straight edge diagonally from one side front to the other side rear and try the same thing.
Sometimes, if you ask real nice at the machine shop you have check the cylinder head, they will loan you a straight edge so you can check your block at home. Of course it helps if they have your head for collateral.
Hth
Mark A.
