Good. Temps have rarely been over 200. I still get the odd noise/shudder if I launch too hard from a light or something like that, but it was flawless on any somewhat recent 4x4 trips I've done.how is your tranny holding up jeff? I finally got angelas to the tranny shop and I need a new TC and pump!! ugg
And the update....
I had my truck in with Dr. Voo to perform a proper transmission flush (day surgery, no anesthetic required). He had his pump all hooked up and working away, but noticed that after 10 minutes or so barely any fluid had been pumped out. It turns out she was indeed too fat and had a blocked artery, one of the transmission cooling lines had failed internally and was blocking off cooling to both radiators (OEM and the aftermarket tranny cooler).
Once this hose was replaced, the flush commenced properly and then topped up with 15 litres of fresh fluid. I opted to stick with regular fluid, mostly because "holy **** is that synthetic expensive"!
I then had a "Glowshift" 3 in 1 gauge installed to monitor boost pressure, EGT, and of course transmission temperature. This new gauge replaced my single boost gauge in the same location.
With that all done, it was time for some real world testing. Off to Whipsaw!
It would have been interesting to see what my EGT's have been prior to all this, as I have always pushed this truck pretty hard going up any hills like the Coquihalla snowshed, trips to Utah, California, etc.
The big test this day though was the Hope/Princeton highway and the hill going up Hope slide. I'm going off memory here, as this was over a week ago now. Up the hill at about 80 km/h (more like 90 with the tire correction factor), boost at 18 PSI, and EGT peaked at 1400something degrees. I still dropped it into 3rd to keep revs up, as D just doesn't like to keep up on these long pulls, and about 2500 rpm.
Transmission temps peaked at around 200 degrees. The highest transmission temperatures I saw all trip were 215, and that was doing the Lawless FSR on the way home, tailgunning several trucks.
So the prognosis is good, and seems cured. Long term who knows, but I live in the moment and the moment is good.
The rest of you are now saying....Holy &^&*^&((( 1400 degrees???!!!???
If I just punch it to merge into traffic onto the freeway where it's flat, I hit 1300 degrees damn near instantly, but as soon as I lighten up on the throttle the 3" exhaust cools it down rapidly to 500/600 degrees.
And this is with my fuel adjusted and aneroid rod modified again so I have considerably less smoke than before. I can only imagine I would have been hitting even higher temps prior to this.
edit: And yes I am working! Waiting for renderings to complete while I type this![]()
