A couple of days ago, the A/C seems to be making some noise regardless if the clutch is on or off. Sounds like a belt or bearing noise from the pulley area (confirmed with a stethoscope) I was wondering if there is a bearing to replace there or should I replace the whole clutch assembly? The clutch works fine and does engage/disengage as needed. I also noticed some signs of grease leaking from around the pulley.
Cheers,
Cheers,
